2001 1500 Silverado Limited Slip???
How does the limited slip in my '01 1500 Silverado work?
Are there clutch packs that slip on turns?
Seems to me that the opposing wheel with get powered once the other wheel slips.
There is a set of springs between the two spider gears that drive either axle shaft which presses clutches into the gears, and creates a considerably strong drag force whenever they try to spin at different speeds, thus creating the limited slip effect. When you rebuild your limited slip differential, you simply remove the innards and replace the clutches.
When I checked the limited slip in a snow filled parking lot the one wheel would spin several revolutions and the opposing wheel would then spin with the original wheel.
When I was growing up my father told me the standard way to check the limited slip was with both wheels off of the ground you spin one wheel and the opposing wheel will spin the same way. With an open differential the opposing wheel spins in the opposite direction. When I changed the rear brakes last week I did this test and the opposing wheel turned the opposite direction.
If I bury the accelerator both whhels will put down rubber.
What Gives???
Is this a somewhat different type of limited slip?
What Gives???
Do you actually have an Eaton G80 (like my 03 Avalanche has)? If so, it's not a limited slip. it's a speed sensitive automatic locker.
What Gives???
tree hugger is correct. You don't have a limited slip you have a G80 locking rear end (look in your glove box) it is made by eaton and will work good if not abused.
It senses speed differences between the 2 wheels and locks if it is more than 100 rpm diff.
The GM trucks don't use a "limited-slip" differential,but the "automatic-locking" differential (RPO Code G80) as was said earlier.
The opposite wheel/tire will turn in the opposite direction if you turn one by hand while up in the air,This is because the "G80" is designed to function as an "open" differential until it senses slippage (When the wheel-to-wheel speed difference is 100 RPM or more) then it will "lock" the two axles together (The entire locking process occurs in less than 1 second) but only up to 20 MPH.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 294 Guests (See full list)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
