Best tires for heavy towing
The truck is a part time tow truck. I use it for repo work.
What are the best tires for the price with an "E" load range?
If you don't care about snow traction, the Michelin XPS Rib's will handle way more than they're rated for. They have steel belts and STEEL SIDEWALLS.
You know here in MI snow traction is a must, especially with a tow truck :confused:
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
