Just bought a Silverado
Just bought a 1999 Chevy Silverado 1500 Shortbed
4.3l V6 Automatic
4-wheel Disc Brakes
64k Miles
2-wheel drive
Anybody know the life expectancy of the engine/tranny on this combo? I payed $7550 for the truck, and i have a 48 month loan out on it...gotta make sure she holds her own.
I've owned silverados in the past...my first vehicle was an 89 Chevy Silverado 1500 Long Box, 305 V8 Automatic...nice long lasting truck (almost 200,000 miles)
Then switched to a doggy slow 1996 Chevy S10, 2.2L Inline-4 Automatic
Just wanted to make sure this 4.3L with the 4l60E tranny lasts a LONG time :cheers:
4.3l V6 Automatic
4-wheel Disc Brakes
64k Miles
2-wheel drive
Just wanted to make sure this 4.3L with the 4l60E tranny lasts a LONG time :D
Hey Drumset,
Welcome to the forum. I think you'll find a nice crowd and a lot of useful information about these trucks.
I own a 1994 Silverado with the 4.3L and the 4L60-E automatic. I've got about 189,700 miles on mine and I have zero worries about driving it across country if I have to. You can check out pictures of mine in the garage and feel free to ask away. :cheers:
I had the same truck (89, 305, long bed 2wd) and it hit 250k before I sold it...I beat the living tar out of that truck. It was even roll tested at about 150k miles. Best truck I ever owned.
You're new truck should be fine, as long as you keep up with the oil and tranny fluid changes.
would love to add a tranny cooler...just wanna make sure the thing doesnt allready have one...it was used for towing in the past (has a tow hitch) so i gotta check under neith to see if the previous owner installed one
It's a great engine. It has a lot of low end torque for it's size. Don't know about the older models but on the newer bodies GM ran the AC low pressure line right over the top of the distributor, and condensation dripped down onto it, causing trouble for some people. Thier solution was to install an insulating foam sleeve over the line. Most of the complaints I have heard on this engine seem to be about the distributor- you might want to keep an eye on the rotor and cap, maybe replace them now and then to prevent carbon tracks from forming and thus causing a misfire.
Well, the good part is, this thing doesnt have AC...hell it doesnt even have vaccum lines to run the dials (i could hear the vents moving as i turned the dials...very hard-LOL) ...this is one stripped out truck...but i will keep an eye on the distributor.
I have a 1999 silv. w/ 140K. (1) alternater, plugs and wires. Thats it!
My Fuel sender / gauge is acting up now (common problem). I will fix this myself soon.
Good trucks as far as I can tell. Change that oil and all other fluids as recomended. I actualy change my oil sooner than recomended.
:cheers::D
Why such a long loan period on such an inexpensive rig? Did they kill you on interest rate?
I honstly don't think you'll have any problems with that truck, the 4.3 is very solid and seeing how you don't have 4WD on it, it'll go a very very very long time. 200,000+ easily. my 99 Z71 on the other hand, <sigh> not even 100,000 and I am very worried.
take care of it and change the oil.  the truck will last a long time.
Ditto! Anything will last a long time if it is maintained properly. Of course, the only variable is whether or not the previous owner took care of it.
Allright, i used an online RPO decoder to read my truck's RPO's ...here they are...
Z83- Solid Smooth Ride
3.08 Gear Ratio (Rear)
4.3L V6
4l60e HMD transmission (HMD?)
Speakers-4 (although it gives this wierd crossover rigamarole stuff...i think i really have 2 speakers
And thats pretty much the basis. Wish it had 3.42's...but alas, it does not.
  • 3 months later...
OUch..........I'm insulted for him..........heck I borrowed $3500, and my loan is that long. Sometimes, us poor guys find it easier to stretch our money out a little, instead of forking over several grand all at once.
Although, I have a good excuse, at least.........I just bought a house.
48 months isn't long anyways..........average loan time is 60 months on a vehicle.........long is 72. :shakehead:
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 636 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
