break warning light on - why?
On my 89 Silverado the break warning light wan't go off anymore. Why?
The break systems seems not to have a leak (aplying pressure to the pedal gradually and steadily - pedal does not sinkto the floor)
The fluid level in the master cylinder is fine.
The parking break switch is operating normal (if I apply the parking break the break warning light will light a little bit brighter).
Besides the master cylinder is a switch. To the upper side of switch is a 12 Volt cable conected.
I think this is the switch for the 2 break systems. How to check this switch?
On one side wall of this switch is a contact (covered with a little plastic cap). Its also with 12 Volts
An ideas??? :cheers:
I have a 90 1/2 ton 4x4 Chevy that had a similar problem. Not sure if the 89's had rear anti-lock brakes, but, the module for the rear anti-lock brakes gave out on mine. I just unplugged it and the light went out. If the light goes out, the module is bad. I've been driving it like that for several years now without any problems.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 1,148 Guests (See full list)
