Headers question
theTANTALIZER
Hailing from Northern California, 2001 5.3L Suburban. I want to (online purchase )JBA titanium coated headers for my 2001 Suburban, but I have 2 choices without air injection w/ EGR or with air injection. Does my 2001 Suburban comes with either of them?
No way to know this for sure without looking at your truck, but since you no doubt have "california" level emissions on the truck, you probably do have SAI.
Look on the "emission" label under the hood. You'll probably see the word CATALYST in big letters and just below it, several other emission items are listed. It will probably say at least egr/h02s/twc and though I haven't seen one lately with SAI, it may have that listed too.
SAI is Secondary Air Injection, or what they used to call AIR, but it's the same thing.
So see if you have egr/h02s/twc/sai (not necessarily in that order).
:driving: You are right on the dot. Thanks for the help.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 371 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
