Horn Broke? Help
My horn does not work no more, i was blowing it the other day and it just quit...i replaced the relay switch in the electronic box under the hood, any mores fuses anywhere i can check?
Therer are two horns on the truck, a high note and a low note horn. One behind and below each headlight. Mine on the passenger side (I don't remember if it is high or low note horm) went out. Had to pull off the airbox to get at it. I found a new one at NAPA for $13.00. I checked the Chevy dealer and they wanted something like $65 for it.
Did you check the fuse...they have problems with the 10 fuse blowing when the horn would ingest water....there was a TSB on it and they made a new version.
I changed out my number 10 fuse to a 15 and haven't had a problem since...
Thanks for the info guys, im definatly going to try the fuse first, but my luck it will be one of those under the headlights. Im going to check tomorrow, ill keep yall posted...
    ballencd
    ballencd
  • Who's Online   2 Members, 0 Anonymous, 445 Guests (See full list)
