steering colunm lock
with the key out of the ignition switch i can turn my wheels .does this truck have a steering wheel lock . have had this 2002 since new ,never noticed it before .
Info - Deletion of Steering Column/Wheel Locking Feature on Vehicles with Automatic Transmissions #01-02-35-003 - (Apr 6, 2001)
2001 Chevrolet and GMC C/K Pickup (Silverado, Sierra) and Utility (Tahoe, Suburban, Yukon, Denali, Yukon XL) Models
2002 Cadillac Escalade
Important
This bulletin does not apply to vehicles exported to countries that follow E.U. Regulations.
Beginning with the 2001 model year, the steering column or steering wheel locking feature is no longer used on the above described vehicles when equipped with an automatic transmission. In previous model years the feature would lock or prevent the steering column/wheel from being turned when the ignition lock cylinder was in the "LOCK" position.
Please advise any customer that comments on their steering wheel not locking when the ignition lock cylinder is in the "LOCK" position that the feature is no longer used on vehicles equipped with automatic transmissions. As a result, no repair attempts should be made.
Important
The locking steering column or steering wheel feature is still used on the above described vehicles when equipped with manual transmissions.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
