Gauge Question / Please Help
2001 Z71 5.3......My tachometer has stopped working.......All other gauges work as usual....The tach was working off and on but seems to of completly stop working......any thoughts on what it might be and what the fix will be ? Thanks in advance
here is a lits of what it could be starting with the most likely failure
1. tach
2. Instrument cluster printed circuit board
3. pcm
4. wire harness
Bobcat, I got in the truck today and it didnt work again but after a few miles it started moving but was very slugish for a few more miles and then it started working right.......So whats invovled with the suggestions you made? Is it expensive to fix.....maybe an extended warranty fix ?
I don't know if on occasion you heard some very quiet grinding noises coming from the tach, but there was a technical bulletin that gave replacement criterion. Apparently it is something called a "stepper motor" that operates the tach needle. God, why is everything so complicated these days?
Here is the bulletin number:
04-08-49-015
It was issued 5/1/2004
who is your extended warranty though
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 888 Guests (See full list)
