stalling...
jamespetkau
i have a 1990 gmc sierra 1500 with the 5.7L, the problem being when i am in gear (forward or reverse) the engine wants to stall at low rpm, however there is no such problem when in neutral or park. before i start replacing parts, i am wondering if anybody knows what this could be or how to know at least what it isn't. the engine is internally stock as well as the transmission. thanks.
Hi James,
I don't know if this is the same thing but it sounds like what my wifes 92 Sunbird went through a few years ago.
I am assuming you are running an automatic tranny. When she slowed down it felt like she was in high gear with a manual tranny and you forgot to put in the clutch, and it would stall out.
Now, I don't have the paperwork in front of me and I can't remember the name of the part but it was some sort of module in the auto. tranny. Wasn't too expensive and it definately fixed the problem. Dealer said it was a common problem. Hope this helps.
Boyd
That's the infamous TCC solenoid problem that affects many 125 transmissions, like you had in that car. His truck does not have that trans and does not suffer from that problem.
Lots of distributor problems causing that in those years. Sometimes, oil would wick up the distributor shaft and soak the inside of the distributor. In most cases, it would just be the pickup coil magnet material deteriorated. At low speeds, not enough of a signal could be generated to trigger the module to fire the coil and the vehicle would stall. Get the RPM's up a bit and this wouldn't happen.
I'd look to the pickup coil.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 371 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
