gear train noise?
topo4u2
Hey GMTECH, hows it going? Nice to know someone is around to answer a few puzzling questions.
I have only owned my 05 Silverado a few months. It has 38000km on it. I have never had it during winter. I heard its a good idea to shift it into 4x4(floor shift) once a month and drive it a couple of kms. no faster than a few miles per hour to keep things lubricated and drive it straight too. I did that today. What I did notice was that while travelling along at a slow pace you could actually hear the noise of the 4x4. It was not loud by any means but very noticable, especially during decel. Is this normal to here it? I would presume you should hear some noise as you are moving a few more gears around. Let me know what you think on this. It would be much appreciated.
By the way, all the dealers around here think im crazy about my 2-3 clunk on shifting but a dealer 2 hours away will re-program computer...no problem.
An '05 for only a few months and it already has 38000km on it? You must do some driving!
There's no need to put it 4x4 once in a while simply for lubrication purposes. The transfer case is always involved, even in 2wd.
As for noise, yeah, they make some. Hard for me to put a quantity on that, except to say, don't expect it to be as quite as in 2wd.
Thanks for the quick reply. Yes, a few miles for a 05 but it was on the road in late 04 and I bought it at 28,000km. Yes, it sure is not as quiet as 2wd thats for sure. I basically just wanted to make sure that its normal to have some noise. Im still working on the dealer here to deal with my 2-3 clunk, slipping tranny(very occasional) and squeeking belts when cold. There is also a tiny bit of play in the steering wheel if you grab it from top to bottom...not sure if thats normal?
Anyway, thanks again.
mike
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 805 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
