Sticking between 2hi and auto 4x4
dolphinsfan1966
2001 Chevy Blazer LT 4x4
my truck seems to have a problem sticking between auto 4x4 and 2 hi, it'll go into auto 4x4 but when i try to get it back into 2 hi, it wants to seem to stick....with both the lights on, 2hi and auto 4x4, and when i turn there's a vibration in the front end, is there anything that can be done about this, or do i just not use auto 4x4.......the only way i can fix it is to take the pos terminal off for a min or so and it seems to reset it
Thanks
Joseph Stone :nopity:
You might want to first try checking for codes. Here's how...
Turn OFF the ignition for 10 seconds.
Connect PIN 13 on the data link cable (DLC) to a ground. The DLC is located in the cab under the instrument panel on the driver's side.
Turn ON the ignition, with the engine OFF.
Observe the transfer case shift control switch select buttons for flashing codes. Refer to Diagnostic Trouble Code (DTC) List .
Important: If the transfer case shift control switch buttons all blink only once and then stop, no fault codes are stored in the transfer case shift control module.
• When one DTC is stored in memory, that code will blink that number of times followed by a 3 second pause and then repeat.
• If more than one code is stored, the first code will blink, followed by a 3 second pause and then the second code will blink.
• This sequence will continue until PIN 13 on the DLC is no longer grounded.
• If the TCCM will not communicate the presence or absence of DTCs, test the above circuits in Self-Test Step 2. If the circuits are complete, then replace the TCCM. Refer to Transfer Case Shift Control Module Replacement .
I dont need a diagnostic analyzer for this? or do i just use a wire to jumper that to a misc. ground?
That's correct. Just ground that pin as described. There's only 4 possible codes you can get. 1, 2, 3 or 4.
just one more question that i should have gotten out there before, do i need to make the light reappear? "service 4x4" before i do this :nopity:
Shouldn't need to. If you've disconnected the battery to reset it as you described, that *might* have wiped out any codes, but I couldn't say for sure.
Give it a try... it doesn't cost anything.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 414 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
