Rear end whine
perksilverado
Rear end whine in my 2005 Silverado
I have a 2005 Silverado I purchased new in July of 2005 with 8 miles. It is a regular cab long wheel base with 5.3, A/T, and 3.23 locking diff. The rear end whines mainly on decel between 38 and 50 mph. It also occurs at 70-80 mph.
A local Chevy dealer agreed it was too noisy and replaced the Ring and pinion, pinion bearing, seal, and oil at around 3000 miles. After they were finished it whined just as it did before. I do not recall it making this noise when the truck was first purchased. We discussed the fact that the truck has the work truck interior package (vinyl seats-rubber floor mat etc.) and may not be insulated from noise as well as a higher optioned model. They said this is probably as good as it gets. I thought about this for a few days and listened to it whine some more.
I later rode in a 2004 Silverado equipped identical but with a 3.42 locking diff. It made no noise at any speed. I then drove a 2006 Silverado identical to mine with 3.23 ratio locking diff. It made no noise. The Chevy dealer said they would check into this issue. As of last week they do not have an answer.
I really like this truck but am very disatisfied with the noisy rear end. Has anyone else experienced this problem with this model? Any info. or help is appreciated. Thank you. perkssilverado
I was going to ask this same question last week about my new 2006 2500HD with the 4:10 rear end. However, it's currently at the dealer getting an entire new rear axle assembly because the factory didn't put any diff oil in it and the dealer prep didn't inspect for it like they're suppose to.
Yours sounds like classic gear backlash noise, louder on decell is classic backlash noise. I had a shop take three tries on a Ford 8.8 rear gear change to get the backlash set correctly to eliminate the whine on decell.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 490 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
