Whats the difference?
Other than wieght difference and gearing, whats the big differences that make the 6.0 in the vette so much faster and more powerful?
This is pure speculation.
LS2 vs. LQ9
LS2 is high compression, more agressive camshaft, different intake ect. I would emagine that these motors have zero in common other than displacement.
http://www.gm.com/automotive/gmpowertrain/
Thats probably a good place to look.
The LS2 has 400hp/400ft-lbs of torque and has a 10.9:1 compression ratio (probably requires premium gas) with a cast aluminum block. . .the LQ9 has 300/325hp and 360/375ft-lbs of torque with a 9.4:1 compression ratio, and has a cast iron block.
Bore and stroke are the same. Both have aluminum heads.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,189 Guests (See full list)
