Backup Sensor Module install
cubythewater
i have a 2004 GMC Yukon Denali, and would like to put the Escalade style reverse sensor system in. I would guess that the wiring harness should be ready for the GM module to be installed, can anyone help with this?
I figure I can purchase replacement sensors, module and dash fittings from the caddy parts bin, but I dont know where to put the module and such.
Help?
You would guess wrong then. They don't put in harnesses for things that the vehicle didn't come with. Maybe a single power connector here and there, a ground maybe.
I assume you're talking about the "Rear parking assist" system? the one that has the 4 little circular sensors across the bumper? Not a very useful system if you ask me. Unless you're used to backing up at 1/1000th of a mile an hour, they don't help much.
I think your money would be better spent on a camera system to view what's behind you.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 523 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
