feul pump noise
JACKFAVOR
On my 99 Tahoe you could all ways hear the fuel pump when you truned on the key but not when the engine was running now it is a lot louder you can hear it with the engine on in the truck does this mean the pump is about to go?
Thanks
Jack
Could mean the fuel filter is clogged enough to make the pump have to work harder. I don't really have any statistics on pumps getting louder meaning they're about to fail. So I guess my answer will have to be, maybe/maybe not.
A few years back I took my 98 K1500 Suburban in to the dealer about Fuel Pump noise,I had extended warranty up until 100.000 miles,it had 66,000 miles.The warranty man came by chevy to verify this and said it was OK,never had it replaced now I have 146,000 with same pump. :fume:
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 521 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
