Without rubbing??
Okay so I have this 2006 2500 HD 4x4 with the smallest tires on the planet. Well maybe not on the planet but you get the point here.
How large of a tire can I go on the factory wheel without getting into a rubbing when turning issue.
Also has anyone installed a 20" wheel and if so what size tire did you go with. Might look into that this summer and knowing what size would be great.
Thanks for your time.
A 265/75/16 will clear without rubbing. A 285/75/16 will probably require some minor trimming... ( I think GMC's have a different front air dam than the Chevys')
However, the factory rim is narrow, and even a 265/75/16 is wider than what is recommended for it. (although this is the size I'm running)
Some tire dealers may be reluctent to mount a larger tire on the stock alloy. I had my Revo's mounted at Walmart, but I had to take the rims in "off the truck" because the door jam does not show a larger tire option for my truck...
I have a 2005 HD and I was told that aftermarket 16x8 wheels would not fit and that I would have to go to 17 inch wheels, has anyone installed 16x8 aftermarket wheels on there 2005 HD? AKGMC where are you at I live in eagle river.
I've got 20" x 9.5" Weld Velociti 8's with 305-50's on my 2500LD. The HD sits a little higher so there shouldn't be any rubbing issues.
Good Luck! :fume:
Hey there SS, I dont suppose you have any photos of your truck with those wheels and tires on it do you? That is the same size tire I was looking at and kind of leaning towards those wheels as well. Either those or Foose Spank 8's.
I have an 02 2500HD My wheels are 16X8 Ibelive with 315's on them. The T-bars are cranked all the way.
Here is what it looks like:
As you can see the bumper is trimmed and there is still rubbing. The innter fender wells are torn up at the edges.
I need to get a 6.5 lift if I want to keep running these tires. The truck was set up like this when I bought it but I do like it.
Bob
I don't have a place to host my pix so I can't post them here. If you PM me and give me your e-mail address, I'll send them to you.
SS
Edit: Try these posts:
Pic 1
Pic 2
Pic 3
I had 305-70-16 on my 2001 2500 HD with the victoria performance lift keys and the tires still rubbed even with trimming the air dam and inner fenderwells. I hated the rubbing so I sold the tires and bought bfgoodrich rugged trail tires in 265-75-16. No more rubbing, great traction on snow and ice as well as towing my toy-hauler travel trailer. Just my 2 cents.
Chris
Anchorage, Alaska
CWH did you install the keys yourself or did you have someone in town do it for you? I have been looking at getting it done, I saw that Johnsons tire does it for about 500 but not sure what all they install.
Piece of cake,
Tools required are a heavy duty two jaw gear puller an air impact wrench and an air chisel. I'd be happy to lend assistance. I hate Johnsons tire center. It is helpful to have a couple of extra hands under the truck. Just a side note. It does firm up the ride a bit. Very noticable with the stock 245 tires, but with larger tires it isn't that bad in my opinion.
cwh
:cheers: Does anybody know why exactly they put 245's on from the factory? Is there a distinct advantage with that size tire? (load range or handling?) Or is it just a matter of trying to keep cost down. Also why is the sticker on the door not labeled for any size bigger??
Thanks a bunch!
Thanks a bunch!
I'm sure there is a cost issue along with other things. Most importantly, there isn't a single tire manufacturer that will recommend putting a larger tire on the standard 6.5" wheel.
Actually, a 265/75/16 load range "D" will have a very similar load capacity when compared to a 245/75/16 "E".
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,017 Guests (See full list)
