2wd sliverado/sierra owners with lift?
Is anybody out there running 35's on their 99+ sliverados/sierra's?  If so, how much power did u lose, and what is your gas mileage like?  Also what kind of lift r u running?  Any imput would be greatly appreciated.......thanks
I can't think of anyone hear that has a 2wd w/ 35's, but can I get some specs on your truck?  What size engine, gearing in the rear end, etc.
Did you have any types of lift in mind?  Going for just an aggressive look or do you want to do some baja type stuff where you want a lot of wheel travel.  I'll look up some lift kits for you, but I think fabtech makes a good 6" 2wd lift kit and you can add a 3" body lift for some added height.
Welcome to the forum.
FYI, I've been shopping and just wanted to let you know www.4wheelparts.com sells the 3" for $279.95 while www.central4WD.com sells the exact same kit for $225.00 and only charge $15.00 s&h.  JC Whitney also has the lift for $225.00 but I don't know what they charge for s&h.
I have found www.4wheelparts.com to be about the most expensive out there....The only place I found more expensive is www.truckfarm.com.
--Rick--
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 715 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
