Wet carpet in 96 Yukon
I just pulled some trim panels to install a radio in my 96 Yukon.  When I did I noticed road salt crust at the base of the panels, so I pulled up some of the floor carpet.  It is SOAKED - as in 'dripping and puddles'!
The carpet at the base of the dash was dry so I went rearward (and higher) and found that the rear cargo carpet was wet as well.  It appears that the water is entering someplace in the rear and cascading down behind the rear seats and into the front.
The carpet covering the wheel housings is not wet, nor have I found any wet spots on the headliner.  It appears that the water is coming from somewhere low in the rear cargo area....any suggestions on where to look?  I was thinking rear hatch seal or something around the tailgate....
:angry:  ???  :thumbs:
I remember there being a tsb for this when I had my 99Tahoe.  I didn't ever have the problem, but many others did.  I think it had to do with the seals on the barn doors.  Do you have the barn doors?
Hey Lambinator.....Have you had your windshield replaced lately...had this happen before. Hard to believe but water can leak along top of windshield, run down piller post and inside dash, down kickpad and onto carpet. Check the underside of your dash along metal edge under glove box or emergency brake petal. My problem on 90 Chevy(father in laws truck) actually had water laying there. He needed a new windshield any way so he got new one put in and solved the problem.
Also on brand new 99 Silverado door wheatherstrip was installed wrong at factory and was leaking in that way as well.
Thanks for the info and suggestions....
I have the rear hatch glass/tailgate, which may be the problem...I get wind noise from it occasionally on the highway so I think where there's wind, there's water.
The windshield is original...I'm pretty sure the water is coming from the back as it wouldn't be wet in the cargo area otherwise, but I will do some checking up front too and see if it could be dripping out from under the dash.
    appletrav
    appletrav
  • Who's Online   1 Member, 0 Anonymous, 321 Guests (See full list)
