Should Michael Irvin be fired from ESPN
plainvanilla
Should they??? YES!!!! Will they??? NO!!!! It would turn into some kind of racial issue when it shouldnt be. "If" those were his drugs then that is the reason for firing him and the only reason. But we all know if they do fire him it would be turned into a race issue.
I have my own theory on micheal. First off it wasn't his pipe. It was........... wait for it............... Terrel Owens. See micheal has been worried about poor T.O. Since we all know T.O. must be on crack for the stupid things he's done. It makes sense that with the cowboy's wanting T.O. They sent their best drug counciler to help. Who better than a "CLEAN for years" micheal to help. The Playmaker wasn't saved by the grace of GOD to let his friends battle their demons alone. That and surely J.J. is paying micheal well for his services.
How's that for an imagination.
Hell yes they should fire him. I don't care about the drugs, he's annoying as hell and I can't stand him. I think they need to steal Terry Bradshaw and Howie from Fox. Those guys are freaking hilarious. But that's just me.
Limbaugh is an inflammatory jackass (not to mention idiot and hypocrite), and everybody knows it...That's why he got fired.
ESPN knew what they were getting with Limbaugh and he did exactly what ESPN wanted him to do, create controversy...their ratings were down so they needed a little pick me up...do you really think ESPN is that upset about Irvin getting caught...i would bet not...so if they do fire him it will be awhile...they will let this drag out just to get more viewers
Drama queens.... :cheers::crazy::smash:
I think limbaugh knew that the his drug problem was going to go public so he got himself fired on purpose.
Everybody's entitled to their own misinformed opinion.
Limbaugh is great on radio but bad on TV.
He is just one of those people who don't go over on TV. He tried his own show back in the 90's and it flopped.
He is entertaining as heck on the radio but just does not have the same charisma on the boob tube.
I thought that O'Reilly would struggle on radio, but to my surprise he has mastered both equally.
Just my humble 2 cents... :flag:
Personally I can't stand Limbaugh on Radio or TV.
Nor would I enjoy Bradshaw on ESPN, he's the reason I don't watch the CBS pregame show.
I love that guy...Probably has something to do with him winning the Superbowl waaaaay back when that infected me with SuperSteelerFanItis. My whole family was pulling for the Cowboys, so I (being what...5 years old?) just had to pull for the underdog Steelers. Then they won. I've been a diehard fan ever since. Might be why I like him.
That, or the fact that him and Mel Tillis were funny as hell in The Cannonball Run :gmc:
O'reily and Limbaugh are both tools that need their mic's shoved up their wazoos most of the time.
Bradshaw and Howie are total idiots that should not be put in front of a camera...they need to put Aikman and Moose (Daryl Johnston) in studio and make ol Terry a sideline reporter.
I am an old fan of Terry also. He was not a natural athlete at that position, but he played his guts out and made it. I love what he told his team in 76..."boys...you can loose with me...but you can't win without me....
ONE FOR THE THUMB!
As a player I think Bradshaw was great.
Howie is one of my all-time favorite players (I am a Raiders fan).
I think both lack alot in the studio, but Bradshaw just gets on my nerves everytime I see him on camera.
As for Aikman, I think he's a little too boring for the pregame shows. Leave him on the booth.
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 700 Guests (See full list)
