Strange RPO Codes
rudder73
My 2000 Silverado has the following codes for which I can find no information:
ZCJ
1SZ
6MT
7MT
92D
92I
The VIN is 1GCEC19TXYZ156098
I found no information using google or autocheck for these codes.
Here are the options on your vehicle... two to each line...
OPTION CODES
AJ1 - DEEP TINTED GLASS AM7 - FOLDING REAR SEAT
AU0 - KEYLESS REMOTE DOOR LOCK AND TRUNK OPENER AU3 - POWER DOOR LOCK SYSTEM
A31 - POWER WINDOWS A95 - HIGH BACK RECLINING BUCKET SEATS WITH FLOOR CONSOLE
B30 - WHEELHOUSING & FLOOR CARPETING B32 - FRONT COLOR-KEYED FLOOR MATS
B33 - REAR COLOR KEYED FLOOR MATS B85 - BRIGHT BODY SIDE MOLDINGS
C60 - AIR CONDITIONING DK6 - OVERHEAD CONSOLE
D07 - CUSTOM FRONT FLOOR CONSOLE D48 - ELECTRIC EXTERIOR MIRRORS
EVA - EVAP EMISSION REQUIREMENT E63 - FLEETSIDE BODY
FE9 FWI - FORT WAYNE PLANT
GU6 - REAR AXLE 3.42 RATIO JC5 - 4 WHEEL POWER DISC BRAKES
KNP - HD AUX TRANSMISSION COOLING SYS K34 - ELECTRONIC SPEED CONTROL WITH RESUME SPEED
K68 - 105 AMP DELCOTRON GENERATOR LM7 - VORTEC 5300 V8 SFI GAS ENGINE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE NF2 - FEDERAL EMISSION SYSTEM
NP5 - LEATHER WRAPPED STEERING WHEEL PF9
QCJ - P255/70R16 ALS WOL TIRES Q4B - 6,200 LB GVW RATING
SLM - STOCK ORDERS UP0 - ETR AM/FM STEREO W/SEEK/SCAN, DIGITAL CLOCK, THEFT LOCK, SPEED COMPENSATED VOLUME, COMPACT DISC PLAYER, CASSETTE W/AUTO REVERSE AND AUTO TONE CONTROL (REPLACES RADIO IN STD/OPT PACKAGE)
UQ3 - ENHANCED AUDIO SPEAKERS VB3 - CHROMED REAR STEP BUMPER
VG3 - FRONT DELUXE CHROMED BUMPER VXS - COMPLETE VEHICLE LABEL
V22 - DELUXE FRONT APPEARANCE V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XCJ - P255/70R16 ALS WOL TIRES X88 - CHEVROLET CONVERSION
YCJ - P255/70R16 ALS WOL TIRES YD3 - BASE EQUIP FOR SCH GVW PL-FT AX
YD6 - BASE REAR SPRING YE9 - SILVERADO
ZCJ - P255/70R16 ALS WOL TIRES ZY1 - SOLID PAINT
Z85 - INCREASED CAPACITY CHASSIS PACK 1SB - OPTION PACKAGE 02
1SZ - PREFERRED EQUIPMENT SAVINGS 41U - BLACK
6MT - COMPONENT FRT LH COMP. SEL SUSP 7MT - COMPONENT FRT RH COMP. SEL SUSP
92D - MEDIUM GRAY CUSTOM CLOTH 92I - MED GRAY INTERIOR TRIM
ZCJ-Spare tire P255/70R16 WOL RADIAL ALL-SEASON
1SZ-Option Pkg. (IT DOES NOT TELL WHATS IN IT)
6MT-Component-FRT LH Computer selected suspension
7MT-Component-FRT RH Computer selected suspension
92D-Trim combination cloth,Pewter (Med. Gray)
92I-Interior trim,Pewter (Med.Gray)
JJG=FRT END SUBASSEMBLY INSTALLED (MODULAR OPTIMIZATION,FRT END SUBASSEMBLY)
Now don't ask me what it means 'cause I have no idea! :gmc: But if I had to guess it is more for the assembly plants use than us dealers,A lot of times there are codes on the label that do not even come up as being good or codes such as this one that us dealers never need and they end up being codes just for the assembly plants use and reference.
Thanx for your reply.
Is it normal for a Chevrolet to have a GMC suspension?
The X88 RPO is for a Chevrolet Conversion Nameplate and the Z85 is a GMC High Payload Sport Package.
The only difference between a GMC and a Chevy are cosmetic. They're the same platform and built on the same assembly line.
Every once in a while, we get a new "Chevy" off the transport truck that has "GMC" emblems on the grille and back end.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 523 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
