I have found 12497459 as the possible part number for an engine block heater. The description is:
5.3 liter MFI 8 cyl engine, 6.0 liter MFI, HO, V8, iron engine (6.0N), 4.8 liter MFI 8 cyl engine, 8.1 liter MFI 8 cyl engine (496 CID), 5.3 liter flexible fuel (gas/alc) 8 cyl engine with MFI.
Notes: t/w gasket 12560438 for vehicles w/LQ4 or LQ9)
Can you verify this would work on my 2003 5.3L 1500 4x4?
Will I need the gasket?
Thanks!!
  • Replies 117
Top Posters In This Topic
Thanks!!
whatever the #, just make sure it doesn't have the thermostat in the plug otherwise it will render the heater useless above 0F, which is about 20 degrees too cold for me... :gmc:
It will work for you,However part number 12497459 has been changed to a new part number,17800530.
Either one will work.
(You won't need the gasket,The reason you need it for the 6.0's is because you must remove the engine oil cooler line from the block which the 4.8/5.3's don't have)
One other note that I forgot to mention that the instructions don't tell you,If your truck is a 4x4,To make it easier to install the heater remove the front driveshaft from the front yoke,You don't need to completly remove it,just the front half from the yoke.(It takes an 11mm wrench to remove the bolts)When you do just push the driveshaft back towards the transfer case and lower it outta' the way,You might already know this but just in case,Be sure not to turn the driveshaft once removed from the yoke.(You want to install it back the same way for balance reasons)
If you have any other questions let me,I've installed a few of these over the years and have it down to about a 1/2 hour-45 min. job!
Thanks for the insight. Which plug do you take out? The rear most? Does anything else have to come off to reach up in there?
The one you remove is on the drivers side rear,above the oil filter,Its a brass 17mm hex-plug. (So you'll need a 17mm hex socket,plus a 24mm regular socket to install the heater)
Nope,You do not need to remove anything else.They don't even tell you to remove the driveshaft in the instructions,but man does it make it easier to install! :banghead:
Let me know how it goes :cheers:
Oh, so I'm not taking out a freeze plug? This is what's going in:
That looks to be the standard freeze plug size. If this is just unscrewing a plug and putting this in that seems much easier than yanking out a freeze plug. My only other experience with doing a block heater was on a 1979 Toronado 350 diesel conversion motor. :banghead:
Nope,Its not a regular type freeze plug,It is threaded and actually screws in and out of the block.
The picture you have there is same one I have here at the dealership and is a "generic" picture so-to-speak.
Your heater will have threads on it.
Hey, I thought of a couple more questions. First, how much coolant am I going to lose? Second, I've seen the recent posts about these heaters possibly having a thermostat that keeps them from working above 0 degrees C. Is this true?
You'll lose about 3 gallons if you drain it from the radiator,If you just remove the plug and let it drain from there (Or shall I say "shower" you. Be prepared if you drain it this way,it goes everywhere!) You lose a little over 2 gallons.
I always use distilled water for mixing with the Dex-Cool.
I really never noticed the thermostat or "tumor" thats on the end of the plug that everyone has been talking about,I do know this though,I've plugged mine in many times when the temp. is above 0 degrees,but below 30,and it works.
OK,Just to update you,I plugged my '04 in last night for the first time ever since I had it (It never really got cold-cold here last year so I never tried to used it) And lo-and-behold it DIDN'T work,It got down to the upper single digits/low teens but not below 0.
I know all my previous trucks (Which included a '94 S10 ZR2,'94 & '97 K1500 "OBS" trucks and a '99 K1500 "NBS" truck) worked no matter if it was below 0 degrees or not,so they must have put some kind of thermostat in the plug over the last couple of years :banghead:
I know I'll be switching out the plug end like everyone else has done!
Hmm, thanks for checking. Are guys just cutting off the end and wiring in a replacement plug? Is it possible for you or someone to call the techline and get a confirmation?
<{POST_SNAPBACK}>
Since I have been trying to get a definitive answer on this for some time now, I asked around with a couple of tech's in the chicago area about this thermostat controlled plug...one had no idea what I was talking about, one said it has always been that way (which it hasnt, my 95, 99 and 02 all worked regardless of temp) and finally the third guy said that he BELIEVES gm changed something internally in the engine and now does not want the block heater maintaining a constant 180 F when it is above 0 outside for fear of POSSIBLY damaging something internally...
Please, is there someone out there that can get a straight answer on this? I'm freezin here...
Guys give me a day or two,When I get a free minute (Been out all morning plowing the lot here at the dealership!) I'm going to call GM-Partech on this and see if they can tell me something (I'm not holding my breath though!)
Arctic,Your right it wasn't always like this,As I said in an earlier post before all my other trucks worked no matter what the temp.
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
    • I had a similar but different response when I talked to the service manager where I bought my truck in that he said GM corporate won't allow them to lower the placard pressure setting as they would get their hand slapped but that of course they have the ability to make that change. His suggestion was simply go to a tire dealer or third party shop that is willing to reset the pressures lower. However I chose to buy a tpms tool and partly based off of this very forum as it had been proven to work on the 2024 model ( Global B system ) and while I could have paid lots for a full two way diag tool, I didn't want to spend that much and bought the recommended Autel TS 508 and it will reprogram the 2025 model and assume it should do the 2026 as well. However the tool is rather proprietary to reprogramming Autel tpms sensors so that is a function I will never use, where as a real two way scanner would have many uses but also have yearly subscriptions etc where this 508 is free updates for as long as they put updates out for the unit. In any event it worked to lower the placard pressures and I often use it to adjust my actual tire pressures although will check with a mechanical gauge as well sometimes just to make sure that tires tpms sensor isn't lying to me.    My suggestion is either buy a tool that you know will work to adjust the system or start out by getting the tire shop you bought your tires from to reset your truck and if after that you still want a unit to do it yourself, get one at that point.
    • Here is an image of a quick Google search about these tires on my truck and it's exactly same psi recommendation the Toyo tires company gave me!    I'm not looking for anyone else recommended psi or anything, I'm just looking to see if anyone knew a way to get rid of the factory low psi warning light, because I'm not running high psi and ruining my tires when I'm not towing!
