EGR valve - Code P1406
I just pulled code 1406: My EGR valve is not performing right. Is it worth trying to wire bush/clean-up the old one or not? The part is easy to change out, only two bolts, but its about $130.
Thanks
Steve L
I had the same about a year ago on my 2001 5.3. Took it off. Cleaned it up. Put it back. Has been fine ever since. Donate the $130 to the Red Cross. They need it.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
