wiper module
jmelrntz
i know that on some of the 88-98 trucks gm recalled the wiper module. i'm wondering if there is a vin code i can check to see if my truck is one of the recalled. or a serial number on the wiper module itself. seems like after i use the wipers a while they just go crazy. will run constantly after being turned on, even if you turn them off. then when they do turn off they will stop mid windshield sometimes.
    Fishboat
    Fishboat
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
