Help!! GMC Envoy Navigation Lock Out
brad235
Does anyone know how keep the destination programing active when the vehicle is moving. It locks out certain functions of navigation while vehicle is in motion. I would like to know if it is controlled by voltage or something else. I found a green/white wire that drops voltage to 6 volts when the vehicle is underway and I put 12volts on it and it did not change. PLEASE ADVISE!
Thanks
The wire you found is the vehicle speed signal, which is what it looks at to know the vehicle's moving and lock out certain functions. I'm sure someone here has the answer as to how you can thwart it so the radio doesn't know the vehicle's moving.
    Fishboat
    Fishboat
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
