trouble code p0010
mbowerma
Pretty serious, because there is no such code.  :)  Go back and check again and see what it really is.
This is what I found
My reader aslo shows a P2149 , P0401,
P 0404 and the aformentioned P0010
Still no help?
I am new at using a reader I think maybe I have to tell it what vech I am checking. I will get back when I learn more
Thanks
z
I think first we need to start with what model year and type of vehicle this is and what engine.
The info is in my avatar. It is a 2004.5 2500hd Duramax LLY . It has 28000 trouble free miles on it. The codes came within 36 hours of putting on the winter cover. It will start but has no power when in gear will get up to about 1600 rpm. Does not shift and will do about 15 mph. Dealer is coming to get it this morning.
I just wanted to know how bad a problem this might be.
No P0010 DTC exists for that engine/year. What are you scanning with? Perhaps it's giving you some misinformation.
There's an updated calibration for false setting of P0401 and P0404. The P2149 is for a FICM (fuel control module) issue. We've had some problems with the terminals breaking in injectors #2 and #7. This is because the harness isn't supported and the resulting vibrations break the terminals at the connector. THere's a bracket kit to fix this.
Thanks
Dealer ordered new injector harness and mount brackets
When you say an updated calibration is that done with flash update?
Oh yeah never got a repeat of the p0010. I was using a product called a scangauge the dealer used what I belive was a Tech II ?
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 901 Guests (See full list)
