Vehicle Info:
XR Man
1999 Silverado 5.3
GMTECH could you please run this truck? It has quite the warranty history and I want to know what has and has not ben done.
1GCEK19TXXZ204314
Thanks
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/20/2003 385499 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 35746 miles
01/20/2003 385499 # F0060 - SLIP JOINT, PROPELLER SHAFT (BETWEEN TRANS AND REAR DIFFER 35746 miles
01/20/2003 385499 # J5560 - REGULATOR AND/OR GASKETS, FUEL PRESSURE - REPLACE 35746 miles
01/20/2003 385499 # F1440 - SEALS, FRONT DIFFERENTIAL OUTPUT SHAFT - FRONT - RIGHT - R 35746 miles
06/06/2002 125469 B N0528 - BULBS, LAMP - EXTERIOR - REPLACE 26106 miles
06/03/2002 125469 # J5485 - BODY, THROTTLE - R&R 26106 miles
03/11/2002 124119 # C2085 - CUP HOLDER, INSTRUMENT PANEL - R&R OR REPLACE 23038 miles
03/11/2002 124119 # N0528 - BULBS, LAMP - EXTERIOR - REPLACE 23038 miles
03/11/2002 124119 # E7420 - SHAFT, STEERING COLUMN - REPLACE 23038 miles
03/11/2002 124119 # C0183 - REGULATOR, FRONT DOOR WINDOW - LEFT POWER - R&R OR REPLACE 23038 miles
03/11/2002 124119 # F0060 - SLIP JOINT, PROPELLER SHAFT (BETWEEN TRANS AND REAR DIFFER 23038 miles
03/11/2002 124119 # C7750 - COVER AND/OR PAD, FOLDING SECOND SEAT BACK CUSHION - SINGL 23038 miles
04/13/2001 118444 # V0523 - REPLACE DRIVERS & PASS SEAT BELT RETRACTORS 17204 miles
04/13/2001 118444 # V0609 - INSPECT BRAKE PIPE & INSTALL SPACER CLIP 17204 miles
11/10/2000 115970 # C7484 - BRACKET, REAR SEAT FRONT PIVOT FLOOR - REPLACE 13525 miles
06/06/2000 049158 # C0530 - GLASS, QUARTER SWING OUT - RIGHT - REPLACE 7723 miles
06/06/2000 049158 D C0530 - GLASS, QUARTER SWING OUT - RIGHT - REPLACE 7723 miles
06/06/2000 049158 # C0531 - GLASS, QUARTER SWING OUT - LEFT - REPLACE 7723 miles
06/06/2000 049158 D C0531 - GLASS, QUARTER SWING OUT - LEFT - REPLACE 7723 miles
06/06/2000 113173 # E5247 - BOLT, REAR LEAF SPRING EYE OR LINK - BOTH - REPLACE 7722 miles
06/06/2000 113173 # V0486 - 1999-00 CV & GMC C/K 1/2T P/U - INSTALL NOTICE LABEL 7722 miles
09/24/1999 108819 # J6355 - POWERTRAIN CONTROL MODULE TRANSMISSION REPROGRAMMING WITH 1877 miles
09/24/1999 108819 # K4260 - GASKET OR SEALER, TRANSFER CASE REAR OUTPUT SHAFT HOUSING 1877 miles
06/04/1999 106815 # Z6999 - PDI RELATED FLUID ADDS 7 miles
05/27/1999 A04314 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
