2005 SD & GMC Misc. Parts
RidesGuy
Before they hit ebay or go in the trash, pics are available also if needed. Price does not include shipping. Email [email protected]
1. New 2005 CC rear dome light w/ map lights - $10.00
2. Gray factory Denali trimmed wood passenger side door switch 2003-up - $25.00
3. New 2005 GMC factory molded mud flaps - $40.00 for all four
4. Drivers side heated seats, memory position, and power pedals controller for 2003-up - $15.00
5. Boss TW-24 1.5" pillar monutable tweeters new in box - $20.00
6. Factory stake pocket covers (4 total) for long and short box 1999-up bed rail covers - $10.00
7. New 1999-up textured black front door handles - $20.00
8. New Ride control switch - $15.00
9. New 2005 neutral leather three position tilting headrests - $75.00
10. New 2005 SD white tailgate handle, one tab broken in outer shell, will still fit properly - $25.00
11. New 2005 SD tape\cd player - $60.00
12. 2003-up Denali center console cupholder, has a few scratches - $30.00
13. Used 1999-up rear Hotchkins swaybar kit for leaf spring half ton axle - $80.00
14. 2003-up used black textured mirror covers - $10.00
