temp range
rsz71
My '98 Z71 5.7 runs at about 150 degrees or less. I changed the stat with the factory recommended (I think it was a 195) and it still runs at this temp. Is this temp too low for optimum perf. and mileage, or is this about the correct temp. it should run? I know an engine needs a certain amount of heat to run properly.
Thanks,
Rob
Hotter engines, to a point, running cleaner and more efficiently than cold engines. The major portion of engine wear occurs while the engine is cold.
What is the normal operating temp. for a 5.7 and should I go to a hotter stat?
    250.3k
    Pro Street Jim
    Pro Street Jim
  • Who's Online   0 Members, 0 Anonymous, 461 Guests (See full list)
