What's my ratio?
I have a 97 1500 extended cab 4x4 5.7L Z71.
Can anyone tell me what my gear ratio is? It does have the limited slip rear end, I guess that was an option in 1997 instead of being standard with Z71.
Steve
Here are the codes. Look in glove box for yours.
GT4 Rear Axle: 3.73 Ratio
GT5 Rear Axle: 4.10 Ratio
GU4 Rear Axle: 3.08 Ratio
GU6 Rear Axle: 3.42 Ratio
G80 Rear Axle: Positraction
HC4 Rear Axle: 4.56 Ratio
Thanks Redvett
Thats exactly what I needed
GU6, G80
I was hoping for 3.73, ah well...
That explains why I need to drop into 4-low to get up the big dunes...
Unless you bought the truck used.
The previous owner(s) could have changed out the gear set, so the glove box label will be wrong.
Unless you know for sure it hasn't been changed, best to use the string method.
Tape a length of string to the drive shaft.
Mark a datum. I like pointed straight down.
Roll the vehicle one tire rev. Use the valve stem as reference.
Count the number of whole turns on the drive shaft. That is the first whole number of the ratio.
Fractions of a whole turn is the second half of the diff ratio number.
Remember to remove the string when done.
    appletrav
    appletrav
  • Who's Online   5 Members, 0 Anonymous, 399 Guests (See full list)
