Uniroyal Liberator AT
Has anyone run Uniroyal Liberator AT tires from walmart. I wear out my tires fast no matter what brand I run, so the price looks tempting .
I have a buddy that ran them and they are a decent tire for the price...I was even looking at them but decided to go with some Coopers because they looked more agressive even though they were more costly..
They are not a bad tire, I ran them on my old Ford. BF Goodrich makes it for them, that alone gave me some comfort in buying a Wal-Mart tire. I only had 12,000 miles when I traded it off but they were wearing really good.
had a set on my old 1500 w/t and man those things are great for the price like the other guy said there made buy bfg and that to me was good enoff
plus they do work nice as a at and dont give alot of road noise
all in all id say a dam good tire :cheers:
I had them on my ranger and they rode just as good as the yokohoma avid st's I had on them before. The yokohomas were performance tires and are rated very well. For a AT tire i think they are d**n good for the money.
Hmm...I didn't realize BF Goodrich manufactured those. I almost bought a set but I oped for the BF Goodrich Land Terrain. I felt a little better with BFG stamped on the tires. I've been pretty happy with them.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
