allison trans question?
has anyone tried the bullydog shift improver or the bd brake valvebody upgrade. if so, what is your option of it. worth the money or no? i'm am triing to illiminate the engine fault code at high hp with the banks 6-gun. any feedback would be appreciated.
Don't use the Bully Dog garbage. You will do more damage than good.
No, data on the BD valve body.
I would install a Transgo Kit and after market Converter. While you're in there raise line pressure a little and change the converter valve.
I build pulling Allisons.
Hi jake. i'm familiar w/ the transgo but dont you have to pull the trans? also, can you explane further on raising line pressure & about the converter valve.
thanks, hn
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 530 Guests (See full list)
