Anyone know about the "next"Gen DuraMax
Chris97K1500
I've seen some posts around the internet on sites about either a bigger 6.9L TT DuraMax in the 2008 HD lineup or a 6.9L Turbo DuraMax. Anyone heard anything like this? Just wondering. Chris
The Diesel Place had a couple of posts about the GMT900 HD's and possible upgrades, one was a 6.9L DuraMax. I'll look for the others. Chris
Posts on GMInsideNews also mentions an upgraded 6.9L DuraMax. Most posts on there mention a TT version for better low end torque and much improved emissions (main reason Ford is going with a TT setup with their 6.4L).
All I have seen is the current LBZ was dropped to 16.8:1 Compression Ratio for the future sequential Turbos (One Tiny, One Large) as well as a factory Exhaust Brake.
So did they lower compression, so they can dump more fuel in to make more power? How much did that hurt MPG?
