need tire adive
cyber_gmc
Alright, basically I've been doing some research on tires because I figure i only have a few more months on my current tires. I know a decent amount about all the ratings and sizes, but there's a few things that i haven't been able to find/research yet. I also haven't had any other high performance tires other than the fuzions I currently have and the stock Firestone GTA's.
I've got a lot to say, because I don't want someone to just throw out the tire they like the most. So i have tried to make this extremely long post as easy to read as possible, so please bear with me.
A few things about the Firestone GTA's that came on it.
- replaced them at about 35-40,000 miles don't remember exactly
- my mom drove the car for the first 29,000 miles and drove it like a grandma lol
- I'd say they had about 15,000 or so miles left on them when i replaced them
- the outside tread on both sides of all of the tires were worn a bit more than the centers when i purchased it(i think this was mainly due to the fact that the dealer told my mom that they should have 30psi in them when they were supposed to have closer to 40, max psi was 44)
- wore a bit more evenly after I got it because i ran them a little harder(around 42-43psi warm).
- they sucked in the snow, but they were also pretty worn when my first winter hit with the car.
I'm currently running a set of Bridgestone Fuzion ZR-I 205/50/16's. I did a bit of research on them before buying and they seemed like an excellent deal and i didn't plan on them lasting quite as long as normal all-seasons seeing as financially it didn't matter at the time. But I did figure that with a 320 tread wear that they were going to be decent.
Here's what I would rate them 0-10 (0 = horrible 5 = average 10 = extraordinary) /w comments on each :
dry/warm weather handling 9
- Amazing grip... whether it is a constant corner at high speeds, such as a clover leaf, 90* corners, or quick changes in directions, such as whipping into another lane extremely hard or swerving to avoid an obstacle.
wet/warm weather handling 8
- I was totally impressed with the cornering, performed as well in the rain as my stock firestones did in dry weather.
dry/warm weather traction 8
- Car is an automatic so spining or lighting these suckers up is almost impossible in dry road conditions.
wet/warm weather traction 6
- I would get barely any wheel spin most times, but when they did spin noticably it was nothing too serious
dry/cold weather handling 7
- suprisingly good... not as good as dry/warm weather handling, but really good still
wet/cold weather handling 5
- decent handling, nothing bad, but nothing good... just average
dry/cold weather traction 5
- average traction overall
- rolling traction :
-mashing the gas at 25mph breaks the tires loose 50% of the time(usually when it's colder out) and spins them through the rest of first.
- from a stop
- 55% - a bit of wheel spin off the line
- 35% - spin all the way through first
- 10% - a bit of wheel spin off the line, 4k rpm(powerband really kicks in) tires break loose again and spin the rest of the way through first.
wet/cold weather traction 4
- mashing the gas anywhere below 30mph(won't downshift after 30mph) breaks the tires loose almost everytime
- from a stop
- 80% - spin all the way through first
- 15% - a bit of wheel spin off the line, 4k rpm tires break loose again and spin the rest of the way though first
- 5% - a bit of wheel spin off the line
snow/ice/slush handling 2
- sh*tty as with any summer tire
snow/ice/slush traction 1
- absolutely terrible, on bad days I am only able to get up to 30mph by the end of the on-ramp
tread wear 4
- was really disappointed with the tread wear on these considering the 320 tread wear rating... i figured i'd get about 50,000 miles on them... Since I purchased them(about a month before last winter ended) i've lit 3 of the 4 up 1 time each(no lsd lol) and i drive them hard. So I figured I'd get a decent amount of miles out of them seeing as I almost never peel out and if i do it's just a little bit and in the rain. One tire has nearly no tread left, two have decent tread left(probably 5-10,000 miles left) and one is a bit less than those two i just mentioned. I've put under 30,000 miles on them and even for summer tires/with how i drive it seems like they are wearing way too fast.
looks 8
- look very good, tread pattern looks pretty good(although not the best i've seen) and the side walls look great(minus the fact that i would like them to be lower profile, but 50's are all i could get at the time)
value 7
- Awesome performing tire for the money, but the tread wear sucked.
So now that that is over i'll sum it up... overall i was very satisfied with the tires, however the tread wear was WAY below the 50k I had figured on.
Anyway, i've been shoppin for new quote for my truck, hopin to be cheaper than my allstate, check yours..
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
