Hello Tranny guys. Got some questions.
Ok, Im having trouble with my 4l60e tranny. It wont hold 4th. It starts to go in then drops it into third gear. I did install a transgo shift kit in it.
1. what does the 1-2 3-4 accumulators do??
2. what does the servo do?? mounted on the side of the tranny behind round cover.
My guess is that the problem lies with one of these items. Just not sure what one and why??.
Thanks if you can help.
Doug
Doug
The accumulators cushion the hydraulic application of the band or clutch.
A servo is the hydraulic piston that applies the band. The servo under the cover is the 2nd and 4th servo and applies the 2-4 band. It uses a different piston inside of the servo to apply 4th than the one it uses for 2nd.
Are you thinking that your problem is with the servo? The outermost piston is the one used for 4th.
Good Luck,
Doug
I had a similar problem w/my 4L60e after I installed my TransGo kit, INSTALLER ERROR :fume:
Turned out that while I was re-installing the servo (1-2, 3-4) the one on the side. The spring fell off of the pin, and was laying in the bottom of the chamber. Funny thing is, it was shifting OK for about a week before it started acting up. It was slipping real bad in 1st, then seemed to sliiiide into 3rd. When I pulled the pan to look for damage or any of my screw-ups, the oil pan was loaded with glitter. SCARED THE CRAP OUTA ME :flag: .... Anyhow, I took the valve body and servos out again to re-trace my steps, that's when I discovered what had happened. The servo bore was nicked up quite a bit, but luckily it did not reach the sealing surface of the bore. I was able to reinstall a new set of servo pistons and o-rings with a new spring of course, flushed the pan and replace the filter, I should note that I had also installed a remote spin-on filter in the cooler lines which caught most of the aluminum shavings before re-entering the front pump, so I changed that filter also.....bright side of the story, 18000 miles later, still shifting like a champ. My truck now has over 179,000mi on it. :cheers:
Im hoping thats not the problem. Im guessing its the servo but im not a tranny guy. I should have replaced the accumulators while i was at it but the ones in there looked good. I still have them so replacing them is possible. Just messy and time consuming :cheers:
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 585 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
