Redneck Divorce Letter
PaulieK
Dear Cooter,
>>Me an Sue Ellen have divorced, the judge gave her the double wide and
>>the pickup.
>>So, like the court order said, I delivered the truck before 2
>>O'clock , yesterday afternoon! I took a picture fer proof that I
>>delivered it... Wanted to make sure she found it when she got home!!!
>>How's your day going? See ya later,
>>Your Buddy,
>>Bubba
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 696 Guests (See full list)
