Hump behind seats in Sierra
dikatry
Ok, Here’s a question I have asked some people about this and no one seems to know the answer.
I have two 10-inch subwoofers in a truck box. I have them behind the seat in my 2000 standard cab sierra 1500. There is a plastic cover behind the seats on the floor, when taken off the jack and tire iron are underneath. Also, there is a metal hump about 6 inches high and about 5 inches wide that runs the length of the cab.
What is the hump there for? I have looked at the same year and model Silverado and the hump is not there. Can I cut this out and weld in a flat piece of metal? I don't see why GM would put this there if there were not a reason for it.
The sub boxes I have in there make it so I cant move my seat back all the way, I measured it and if the hump wasn't there I could move my seats all the way back.
Thanks for any help regarding this problem.
Grant
I had a 2002 Sierra regular cab and I remember the plastic toolkit box. In fact, I removed it, and I removed the stud that was left after lifting the plastic box off of it. What remained was a carpeted ledge that went all the way across the cab. It was 7" wide and it was a perfect place to set the speaker cabinet on. When I removed the stud, I just used a heavy hammer and I gave it a few good whacks straight on to the end of the stud, and it broke the tack-weld that was holding it in place on the underside of the shelf.
I remember crawling under the cab first to find the stud and inspect what was holding it there. The ledge that I'm talking about was also visible from the underside of the cab, so it's pretty well permanent.
Sounds like you have something else. Can you post a pic?
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 501 Guests (See full list)
