Oahu, Hawaii: Free Bedliner
vodapas
Aloha,
I recently got a Bedrug so once I install it I'll be stuck with a bedliner that I have no use for. Given its size and the limited space I have at my house I can't really have it sitting around.
So, I figured I'd offer it free to anyone who wants to meet up with me and pick it up. Seems like a waste to cut it up and put it in a dumpster.
Description:
- Not sure of manufacturer. I think it might be DuraLiner.
- In very good condition.
- Made of standard black ABS plastic.
- Fits 99-06 GM full size w/ short bed (6.5").
- Over-the-rail design.
- No stake hole cut outs.
- Has cut outs in bed to access cargo tie downs.
If you are interested or know of anyone who might want it just shoot me a PM or post in this thread. Thanks.
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 561 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
