How To Lube A Silverado's Rear Slip Joint???
Is the slip joint located under the "accordian" type boot? Is there a grease fitting or do you need to take it apart?
So I take it that you have a 4x4 WITH A 2 PIECE REAR DRIVESHAFT right? My '03 is a 2WD but has a slip joint too. Mine dose not have any type of dust boot. There is a zerk on MY truck about 3" from the front of the rear shaft, are you confused yet?
Rich G.
Yep, my silverado is a long bed extend cab. The driveshaft is 2 piece. Right behind the carrier bearing is a boot with 2 clamps on it. Is this the slip joint? Is there a way to remove the boot to lube the slip joint without destroying the boot?
    ballencd
    ballencd
  • Who's Online   3 Members, 0 Anonymous, 455 Guests (See full list)
