Change Engine Oil Light
So, I just changed my oil for the second time that I've owned this truck and now I am getting the change oil light on the gauge cluster within 250 miles of the oil change. I put mobil 1 in and use a mobil 1 filter. I have heard the myth that switching to synthetic after years of dino oil may dislodge some of the gunk in the engine. I switched to mobil 1 at 74K. I've checked the oil level and it is good and the filter isn't leaking or loose. So, do I need to drop another $50 and change it all or maybe a new filter?
Can anyone tell me where to get oil analysis done, just in case.
Thanks
Thanks
(Imagine a sitar playing in the background.)
Ahh, grasshopper, you assign too much smartness to the GM engineers. They are not examining your oil. They are only looking at how many miles, and how many startups, have gone by since the Oil Life Monitor was reset.
You must reset your own oil life monitor. I cannot do that for you.
(P-l-l-ling-g-g.)
You will find instructions in your owner's manual.
(An oboe now plays an oriental interlude.)
Aaaahhh, I see Master. Now I will go and spread my new knowledge to other young newbies. And with that the student becomes the teacher.
p.s. mmmmikkke, where did you learn to play the sitar so well?
LMAO!!!
Hey mike... Do you know sweet home alabama on the sitar?
ps - turn the key to the on position, but not running... Pump the gas pedel all the way to the floor 3 times within 5 seconds and it should say reset on your dash.
You must use your mind to create the sitar, grasshopper. Then you must also use your mind to create the sitar player and the lovely snake charmer with the flute. Now look at the sitar player. Stop looking at the snake charmer! Look at the sitar player! Do they look like they know Sweet Home Alabama? In that you have your answer.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 1,077 Guests (See full list)
