8.1 tune
Newby here, Just bought 2001 2500hd ext cab 2wd 8.1 ally
70000 miles, Feels very strong, Will be pulling 6500 pounds thru mountains in Idaho
I have been getting 11.5 back and forth to work 14mile one way each day.
What could I expect from a wait for me tune? I have 410 rearend.
Thanks for your replies,looking forward to picking up alot of useful info.
Rick
I guess it depends on whether you want an aggresive tune or a gas saver tune. Seems to be a lot of potential in these 8.1L's and a PCM tune helps out a lot.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,201 Guests (See full list)
