High pitch noise- coming from windshield?
When I drive over 65 on windy days I hear a very high pitch loud noise that sounds like its coming from the windshield (not exactly sure though - the pitch is very high and hard to tell where its coming from). The noise can best be described as the ringing noise you hear after a loud concert.   I removed the bug deflector and it did not help.  I have put tape on the sides and top the the windshield to see if it would stop and it did not.  I'm wondering if my billet grill or Brush guard is causing this annoying noise.  I have taken it to the dealer and after a test drive he said that if I wanted they could remove my wind shield and reinstall it.  But I'm not exactly sure if it would fix it.  I would hate to have the dealer do that and it would not work b/c   I'm concerned if he reinstalled the windshield if the quality would be worse than the factory install.  Can anyone tell me what they would do in my situation?   I was thinking of putting some silicon on the bottom of windshield under the molding since I know its not coming from the top or sides.  Its is worse on windier days and at higher speeds
I have also removed the fuse from my radio to make sure its not an electrical noise or the ringing in my ears after listening to my subwoofer :)
thanks for any ideas you have.
Make sure your doors are closed TIGHTLY.  I had the same problem last summer.  The screaming noise seemed like it was coming from the passenger side of the windshield whenever I'd get above 60 mph.  I, too, thought it was in deed the windshield, but it turned out that the rear door wasn't closed tightly enough, thus not creating a good seal, and subsequently squealing at the pressure differences at higher speeds/temperatures.  Good luck.
  • 1 month later...
I get a noise coming from my extended cab's rear windows.  Any way of adjusting them to make a tighter seal?
There was a TSB to replace the rear windows on the excabs.  I had them replaced on my '00...
If you are still under warranty, you should check with your dealer.
As far as the wind noise you are hearing Doug, I'd check to make sure everything is good and tight around the side mirrors.  Sometimes a gap in the plastic (anywhere on the front of the truck) will cause a "whistle" or noise at certain speeds.  About the only way you can find it is by taping up certain parts of your truck and then driving it.  When the whistle stops blowing then you know you've isolated the area.
A freind of mine had a Buick SkyHawk that would make noise at 50 mph.  It was finally isolated to the chrome headlight bezel.  Appearently the gap was just the right size that when air passed over it at a certain speed it began to vibrate or whistle.
To all,
    Thanks for your replies.  I've used all everyone's ideas and I'm still fighting the noise.  I'm going to try taping the doors closed (only one at a time though :)) and see if its coming from one of the the doors.  I'm also going fold  the outside mirrors in and see if it helps.  If nothing helps I'm going to temporally remove the billet grill and brush guard.
Sierra Sam, thanks for the suggestion, I don't have a billet antenna but I'm going to temporarily remove the stock antenna and  see if it helps.
The dealer can't find it , I'll also try another dealer if I can't fix it on my own.  Thanks again
I have a 2002 Siverado 1500, reg. cab, long bed. I also get the same loud and extremely irritating sound. My truck is 100% stock. It sounds like it comes from the base of the windshield on the passenger side. Any ideas how to fix this?
Rich
I'v heard of the winshield problem before. I also believe the dealers are aware of this. I'v heard some dealers take off the windshield moulding and put tape under it. I'm guessing some kind of foam tape.?.
Also on my '99, I heard a whistle and after trying to figure it out awhile I tried folding my mirrors in. It seemed to stop. But I have'nt tried it at a few different speeds to be sure this is the problem. Just another thing you may want to try.
Also I have a question. The extended cab rear side windows seem to be a common problem. Last week I called the dealer and told them my passenger side rear window was'nt closing. They ordered a window kit. Now I suspect the drivers side and I'm thinking of asking them to order another kit. Should the clamps make an audible "click" or "snap" when they close ?
My do not, and it seems they should.      thanks, Rich S
Quarter Glass - Wind Noise
File In Section: 08 - Body and Accessories
Bulletin No.: 99-08-48-001A
Date: September, 2000
Subject:
Wind Noise from Body Side Quarter Window (Replace Body Side Quarter Window Assembly)
Models:
1999-2000 Chevrolet and GMC C/K Extended Cab Pickup Models (Silverado and Sierra) Built Prior to February 1, 2000
This bulletin is being revised to add the 2000 model year, remove service procedures, and change the part numbers. Please discard Corporate Bulletin Number 99-08-48-01 (Section 08 - Body and Accessories).
Condition
Some customers may comment on wind noise coming from either of the body side quarter windows while driving with the quarter windows closed. The wind noise may be more noticeable at speeds over 56 km/h (35 mph).
Cause
An insufficient seal of the window frame to the body or an improper window latch length may cause this condition.
Correction
A new body side quarter window kit is available to correct this condition. This window kit includes the window frame and glass, three frame centering screws that reinforce the sealing of the window frame to the body, and an instruction sheet. The window frame also features a reinforcement latch tab to improve latch efforts and function.
Replace the applicable body side quarter window on affected vehicles. Use the appropriate part number listed below.
Refer to the applicable Service Manual for quarter window removal and additional installation procedures. Also refer to the instruction sheet provided with the window kit for installation information.
Parts Information
Parts are expected to be available from GMSPO on 9-18-00.
Sorry parts number for replacement windows wont post. Email me if you need them
Thanks for the TSB info. I'm glad I still have 3 months left on the factory warranty. :)  I'm not sure my extended warranty would cover it. Just the same it's nice to let the dealer deal with it.   Rich S
  • 10 months later...
Has anyone found a soulution to this? I have a 2002 Suburban with the EXACT same problem and its driving me nuts!  Whistling/wind noise when I hit 70mph, especially when its windy outside,  I can hear it behind the dash, near the windshield.    I have put duct tape everywhere around the front and sides of the truck and cant find it.  Dealer has reseated the winshield 3 times and they still havent fixed it.  I think it must be something else, thanks, PLEASE HELP! THANKS! Mark  ???
Just remember, no matter the quality and professionalism of whoever you have replace your windshield, it is NEVER as good as the original factory install.  It may come close depending on how good the shop is, but I've yet to find one that fits exactly the right way...I wouldn't replace unless you are 100% positive that it is the windshield...just my $0.02.
Uplink, I had a similar noise on my '99 ecab. It sounds like it comes from the dash. Mine went away when it was raining. On my '99 here is a plastic trim on the bottom of the windshield. It is not attached on the top part. I put a matchbook under it and it stopped. Glued it down with clear RTV.
How it works for you.
    • Yes I agree, its what amounts to free advertising to let people know about his UOA testing company, and not that there is anything wrong with that but certainly that is a motivator for putting out videos about the science of oil as well as other topics such as oil and air filtration etc. The interesting part I found with his last video is not only the physics behind the reason for the varying wear due to a diesels working torque range causing more bearing load and that higher viscosity oil is of benefit, it was also that the chemistry behind the GM Dexos 0W-20 and the Mobil Dexos licensed 0W-20 are far enough apart that its showing up with a difference in wear even though the two oils are matched in viscosity and in that comparison viscosity was not having the finger pointed at it.    There are a few youtubers out there or one anyway that I have watched a bit of who has gone through the pains of accessing various countries manuals for a certain engine platform and while in the US/Canada it may say use 0W-20 or what have you for some Toyota product, in some other countries it sings a very different tune for the very same engine with the typical traditional oil viscosity/ambient temperature charts to help choose which oil viscosity is correct for the conditions the vehicle will be used in and in some cases its taken an engine in a US manual that states only use 0W-20 as per warranty coverage and yet that same engine in certain other countries may have up to a 15W-40 etc oil option that meets the spec. Another words the guy who is driving through Death Valley or Phoenix and south weather at 120f is often being fed a line of bs by the US system that has forced vehicle companies to restrict the warranty to a specific low viscosity oil for anterior reasons as well as the long drain interval suggestions.    Thankfully youtube is free ( yet anyway ) for viewers to sift through information and of course comes with the good and the bad ( truth and lies ) and we can choose to turn off/not watch what a person finds is bs or just not interested in the topic.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
    • I agree with this assessment. As you know I’m testing longevity with vehicles for the first time. I have a few vehicles I passed to kids and grandkids. We’re all past 100K miles some approaching 170K. I’m the only one doing 5k oil changes. The rest whatever the minder says. I’m the only one doing frequent transmission service. My odyssey the trip vehicle at 200K will be finished as a trip vehicle. I recently changed to high mileage oil, Valvoline. I can’t get past the fact that all manufacturers want to claim long service life. I just don’t make sense that they would go with low weight oil for mileage. While sacrificing longevity.
