Power Seats
cowher
My power seat won't move forward. All of the other adjustments work. Any input would be greatly appreciated. Thanks
The same motor that moves it forward also moves it back.  Does it not go back either?
I think it is all the way back. I can hear the motor when I try to moveit back but nothing when I try going forward. Thanks Again
  • 1 year later...
I have the same problem with my 2003..
Did yours end up being the switch? is there a way I can test it before buying a new switch?
thanks
-Bill
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
