hi looking for 1990 S10 diagnostic code
tijayfox
Hi to you all from Teresa in Bremerton, WA.
I'm new to this site & I'm trying to figure out what the flashing parking brake light on my 1990 S10 truck means. It's flashing 8 short and 1 long. Any pointers on where to look on this site?
Thanks for your help.
tf :cheers:
tf :cheers:
code shows for a shorted isolation dump valve or faulty ecu
most likely it is the ecu
tf :cheers:
thanks bobcat. i should have mentioned it's a 4-cylinder.
that was quick too! i was just messing around with trying to get into alldata on our local library site, but you have to go in person, not on-line. it figures too because i was just getting ready to sell this truck. my real truck ('95 Silverado 4-by) is getting a new motor right now. i appreciate your time.
teresa :cheers:
tf :cheers:
teresa :cheers:
no problem, I can get any info on any make and model out there, so if you have any questions, need parts at lowwer cost, tech questions, or even to find out if a repair shop is screwing you over
tf :cheers:
teresa :cheers:
cool thanks, i owe you beer. so do you think the code is the same for the 4-cylinder motor?
what's your location on the planet? are you around bremerton? i'm amazed that i can sit on my little place on the planet with a question and there is someone else out there that can and will answer it. very cool.
tf
tf :)
teresa :)
tf
the code is the same for either engine :cheers:
looking at a map i'm about one foot from :cheers:
I am in St. Louis
tf :)
teresa :)
tf
I am in St. Louis
hey thanks.
well, since you are so far away, guess it'll be a virtual beer. you'll have to visualize it.
thanks again, teresa :)
    DaleB
    DaleB
  • Who's Online   4 Members, 1 Anonymous, 1,576 Guests (See full list)
    • If there are updates/fixes you want, you could pay to have the updates applied by the dealer.
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
