FS/FT-1998 Camaro SS with 402ci motor
Looking for a 2002-2004 4x4 1500/2500. Perferably black
1998 Camaro SS for sale. 58,xxx miles. Leather seats, all power, t-tops, alpine cd player, 6-speed. Excellent condition. Oil has been changed every 2,800-3,000 miles with Mobil 1 synthetic.
402ci motor custom built by performance shop in Missouri. (This is NOT the SLP 402 package).
I am the third owner of the car. The previous owner had all of the engine work done. I have not had a single problem with the motor. This car has been my daily driver since I have owned it. It gets 25mpg on the highway. It has never been in a wreck. I have a CARFAX if anybody wants a copy.
ENGINE
LS1 aluminum block-10.5 to 1 compression
Ported/polished LS1 heads
3 angle valve job
Comp valve springs w/titanium retainers
Comp pushrods
Comp hydraulic roller lifters
Jesel shaft mounted rockers
Lunati camshaft-214/224
Ross pistons
Lunati crankshaft
Eagle H-beam rods
Comp timing gear
Optima red top battery
Hp Tuners basic tune
Taylor plug wires
NGK TR-55 plugs
Motor is fully balanced
Every bolt/gasket in the engine has been replaced with OE General Motors parts
INTAKE/EXHAUST
MTI intake lid
LS6 intake manifold
JBA ceramic coated headers
SLP Y-pipe
Flowmaster mufflers
TRANSMISSION/REAR END
T-56 with World Class gears
Upgraded internals(steel shift fork, billet keys, etc.)
Spec stage 3 clutch/billet steel flywheel(approx 10K miles)
McLeod adjustable master cylinder(approx 10K miles)
Pro 5.0 shifter w/short stick
Eaton posi rear end
Trans recently freshened up.
EXTERIOR
18” Boyd Coddington rims
Michelin Pilot Sport-front-255/40/18
Michelin Pilot Sprot-rear-275/35/18
Tinted windows (front, sides, rear)
Painted hood scoop
All of the SS emblems have been painted on the car
SUSPENSION
Eibach lowering springs
BMR tubular subframe connectors
BMR tubular crossmember
Prothane torque arm mount
I have all the receipts for the motor work.
Every part on the car has been installed by professionals.
The car has over $20,000 in extras!
The car made 400rwhp and 420rwtq without the tune and injectors. Yes, these numbers are low for a 402, but I assume it is because of the small cam and shorty headers that were used to keep it smog legal and a reliable daily driver
Previous owner made a few trips from Missouri to California without any problems. It has also passed smog in CA without any problems.
$15,000
Car is located in Springfield, MO
If you have any questions please call (314) 540-7131.
http://img472.imageshack.us/img472/8597/fdriver1zd.jpg
http://img472.imageshack.us/img472/4973/driver0bi.jpg
http://img472.imageshack.us/img472/7900/drear8gh.jpg
http://img472.imageshack.us/img472/4654/rear1lu.jpg
http://img472.imageshack.us/img472/5536/rpass0px.jpg
http://img472.imageshack.us/img472/9242/pass4td.jpg
http://img472.imageshack.us/img472/7492/fpass2pz.jpg
http://img472.imageshack.us/img472/8050/front6mp.jpg
http://img472.imageshack.us/img472/...interior1ut.jpg
http://img503.imageshack.us/img503/...interior4bd.jpg
http://img503.imageshack.us/img503/8969/engine28hd.jpg
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 279 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
