Engine I.D.
I recently bought a 1993 sierra to use as a daily driver. Before I purchased the truck the car salesman said the transmission had either been replaced or rebuilt lately. I also figured the motor had as well considering it has over 200,000 miles. Up until now I assumed it had a 350 in it, no reason not to right. Today was the first time I changed the oil myself(I normally go to a quicklube) The filter that the book at wally world recomended didn't fit. After a trip to auto zone they said the filter I took off of it was supposed to fit a 327. What I was wondering was if anyone knew how to tell the difference between a 350 and a 327 just by looking at it, and if so how?
The filters may be the same. The 2wd small blocks all used the same filter.
The block may be stamped. Either 5.7L or 5.0L typically on the block near the Timing chain cover. If its an older block then you may have to find the casting number.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
