Injectors information needed
Jerther
i'm planning on building a fuel economy display for my truck. And to do so, I will try to do some calculations based on the injectors data. There may be other ways of doing this, but this is one I thought that would be cheap, and wouldn't involve much modifications (just a harmless one i believe).
First of all, I need the flow rates of my injectors. I've got a 1989 TBI 4.3L. After many many hours of googling, I found this table which was took from another site, and it did not originaly have the flow rates for the 4.3 and the 2.8. Here it is:
Chart of GM TBI injector flow rates @ 13 PSI from DIY-EFI list
Code on inj	Engine  Flow lbs/hr	TBI bore	GM part #--------------------------------------------------------------------------Black/White	2.8L  33  35mm  5235430Yellow/Blue	4.3L  45  43mm  5235203Green/White	5.0L  40  43mm  5235279Orange/Black	5.7L PU  55  43mm  5235206Yellow/Brown	5.7L CopCar	65  43mm  17084327Blue/Black	Late BB PU	80  51mm  1708430D Red/D Blue	Early BB PU	90  51mm  5235231
Can you confirm the given flow rate? I think you would be the first to give this information on the internet...
Thank you :cheers:
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 924 Guests (See full list)
