Can you tell if a truck has an allison transmision by looking at the vin#. I'm looking for an 8.1 w/ an allison, but certain websites only list there trucks as 8 cy. gasoline engine and automatic trans......
but the vin # is listed
any help would be greatly appreciated.
All trucks with 8.1L's have the Allison, I dont know if there is a digit on the VIN for the trans, but there might be for the engine which would serve the same purpose. The RPO codes in the glove box are a sure sign of what the truck has too but I assume you dont have access to those in all cases.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
