Trim code location
Where is the Trim Code located on a 2001 Silverado?
I don't see it on the tag on the door that has the vin number.
Where on the vehicle does one find the trim code?
Please!
All of your codes,including the trim codes,are in your glove box on a white sticker (Its called the "SPID" or "Service Parts Identification Label") It will have all of the "RPO" codes on it as well as the VIN,wheelbase of your truck,factory order number,model of your truck (Example:CK15753) and the exterior "WA" paint code.
By the way,Welcome aboard! :seeya:
Thank you! now I know where to find the SPID!!
But, WOW, there are like 11 up and down rows of 5 or 6 number and letters....
Which one is the trim code? And, it would be nice to know what all the other ones mean.... how do you decipher all those things?
And, with a little "educating" myself, I found the link to the RPO Code Guide right here on this page. (That answers what the letters and numbers on the SPID represent)
But I'm still confused...... guess I'm the only one in the world that doesn't know how to figure this out.
Still, my original question has not presented an answer................
I have lots of letters and numbers.... But:
Where do I find the "Trim Code" information for my truck?
Hi, if you are having trouble with the file, maybe a computer question. However, I dont' think the RPO codes on this site have the trim codes.
I have a huge RPO list that I think must have just about everything, it's about a year or 2 old from another site. I'ts in PDF format, so you have to have the PDF reader, normally on most computers or someone has loaded for you as part of another software program - I hope.
If someone wants to post it, it's almost 200 pages, let me know.
Sticky at:
http://www.fullsizechevy.com/forums/showthread.php?t=164851
posted it on that site.
Hope this helps some
Mike
OK,I'm assuming that you want the interior trim code?
Here's some trim codes for '01 Silverado's and the colors they represent:
12V=TRIM COMBINATION VINYL,GRAPHITE
12I=INTERIOR TRIM,GRAPHITE
122=TRIM COMBINATION LEATHER,GRAPHITE
12C=TRIM COMBINATION CLOTH,GRAPHITE
12D=TRIM COMBINATION CLOTH,GRAPHITE
52V=TRIM COMBINATION VINYL,LT.NEUTRAL
52I=INTERIOR TRIM,LT.NEUTRAL
522=TRIM COMBINATION LEATHER,LT.NEUTRAL
52C=TRIM COMBINATION CLOTH,LT.NEUTRAL
52D=TRIM COMBINATION CLOTH,LT.NEUTRAL
92V=TRIM COMBINATION VINYL,PEWTER
92I=INTERIOR TRIM,PEWTER
922=TRIM COMBINATION LEATHER,PEWTER
92C=TRIM COMBINATION CLOTH,PEWTER
92D=TRIM COMBINATION CLOTH,PEWTER
Hopefully I listed your code,If not this should show you what to look for,As you can see interior trim codes start with numbers which will be at the end or bottom of your SPID label.
If I didn't list your code here you can either list your VIN here or PM it to me and I can run it and tell you what interior codes you have.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,058 Guests (See full list)
