VIN numbers
carfax.com - gotta pay though.
what do you need to know? Most stuff you can figure out from the RPO code sticker in the glove box.
Try a search on this forum or google for RPO codes & your truck model / year.
Is there a web site that can give me info from the VIN number of a truck ?
give me the VIN and I will get you some basic info on it. The RPC codes in the glove box will give you the options installed at the factory. Click here to lookup the codes: http://www.gm-trucks.com/rpo/
It doesnt seem to be a complete listing as my truck had some codes that werent on this list. I printed out this page and got a highlighter and went out to the truck and just marked the options that I had.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
