Load Leveling Shocks?
This is probably going to sound like a dumb question, but how do I tell if I have regular shocks or load leveling shocks?
I'm looking into a FabTech 3" lift for my 01 Suburban 2wd and they only mention a kit if its equipped with load leveling shocks.
Other than it being load leveling, what is the physcial difference between a regular shock and a load leveling one?
Well on my 05 Yukon Denali, I can hear them wurrrrrr shortly after startup... the same goes for my dad's 04 Cadillac Escalade.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
